Wat je nodig hebt
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Één opmerking
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
