Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the two sliding battery locks on the underside of the laptop.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
    • Locate the right battery lock and slide it to the right.
  3. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  5. Remove the battery from the laptop.
    • Remove the battery from the laptop.
  6. Locate the RAM cover on the underside of the laptop.
    • Locate the RAM cover on the underside of the laptop.
  7. Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  8. Using your fingers, carefully remove the cover. Using your fingers, carefully remove the cover.
    • Using your fingers, carefully remove the cover.
Conclusie
William
863 Reputatie
7 handleidingen geschreven
Clemson, Team 1-2, Benson Spring 2014 Lid van Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 185
