Ga door naar hoofdinhoud
Toshiba Satellite L305D-S5900 Storage Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: stap 3, afbeelding 2 van 2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Conclusie
Sing Yang Cheng
501 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 301
