Ga door naar hoofdinhoud
Toshiba Satellite L305D-S5900 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L305D-S5900 RAM Replacement: stap 2, afbeelding 2 van 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite L305D-S5900 RAM Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite L305D-S5900 RAM Replacement: stap 3, afbeelding 3 van 3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Conclusie
Sing Yang Cheng
501 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 213
