Ga door naar hoofdinhoud
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 2, afbeelding 2 van 2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 3, afbeelding 2 van 2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 4, afbeelding 1 van 1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: stap 5, afbeelding 1 van 1
    • Fully remove the drive by pulling it all the way out of its socket.
Conclusie
Sing Yang Cheng
501 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 565
