Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop. Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop. Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Lift the keyboard up in order to remove the cable.
    • Lift the keyboard up in order to remove the cable.
  5. Notice the two white tabs on the compartment holding the cable. Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire. Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Conclusie
Tyler GLick
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Leden
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 238
