Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Locate these two screws that you will need to remove.
Undo these two screws with the Phillips #0 Screwdriver.
Use your finger to lift and remove the cover to the Hard Drive.
Pull the black ribbon back and up to remove the Hard Drive.
Pull out the hard drive using the ribbon attached to it.
Bijna klaar!
Eindstreep
