Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Locate these two screws that you will need to remove. Undo these two screws with the Phillips #0 Screwdriver.
    • Locate these two screws that you will need to remove.
    • Undo these two screws with the Phillips #0 Screwdriver.
  2. Use your finger to lift and remove the cover to the Hard Drive. Use your finger to lift and remove the cover to the Hard Drive.
    • Use your finger to lift and remove the cover to the Hard Drive.
  3. Pull the black ribbon back and up to remove the Hard Drive. Pull the black ribbon back and up to remove the Hard Drive. Pull the black ribbon back and up to remove the Hard Drive.
    • Pull the black ribbon back and up to remove the Hard Drive.
  4. Remove the cover to reveal the hard drive. Remove the cover to reveal the hard drive.
    • Remove the cover to reveal the hard drive.
  5. Pull out the hard drive using the ribbon attached to it. Pull out the hard drive using the ribbon attached to it. Pull out the hard drive using the ribbon attached to it.
    • Pull out the hard drive using the ribbon attached to it.
Conclusie
Daniel Matheson
355 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Leden
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 173
