Ga door naar hoofdinhoud
Inleiding
You will learn how to replace a broken CD Drive on a Toshiba Satellite L305D-S5895.
  1. Locate the screw underneath the RAM cover.
  2. Undo screw with your Phillips #0 screwdriver.
    • Undo screw with your Phillips #0 screwdriver.
  3. Push out CD Drive using your finger.
    • Push out CD Drive using your finger.
    • You will have to go underneath the plastic cover of the laptop to access it, as shown in the picture.
  4. Use your fingers to pull out the CD Drive by the face of the drive. Use your fingers to pull out the CD Drive by the face of the drive.
    • Use your fingers to pull out the CD Drive by the face of the drive.
Conclusie
Nathan Merlan
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Leden
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 112
