Ga door naar hoofdinhoud
Toshiba Satellite L305-S5955 Wireless Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: stap 1, afbeelding 1 van 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 4, afbeelding 2 van 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: stap 7, afbeelding 1 van 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: stap 7, afbeelding 2 van 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: stap 7, afbeelding 3 van 3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 8, afbeelding 1 van 1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: stap 9, afbeelding 1 van 1
    • Pull the card out vertically.
Conclusie
Samuel Baker
307 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-2, Baechle Spring 2017 Lid van IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 787
