Ga door naar hoofdinhoud
Toshiba Satellite L305-S5955 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: stap 1, afbeelding 1 van 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite L305-S5955 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L305-S5955 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
Conclusie
Chris
1 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-2, Buehl Fall 2014 Lid van Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 937
