Ga door naar hoofdinhoud
Toshiba Satellite L305-S5955 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Complete these steps in reverse order to insert hard drive back into laptop.
Conclusie
Eric
55 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-2, Buehl Fall 2014 Lid van Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 941
