Ga door naar hoofdinhoud
Toshiba Satellite L305-S5946 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite L305-S5946 RAM Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite L305-S5946 RAM Replacement: stap 3, afbeelding 3 van 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite L305-S5946 RAM Replacement: stap 5, afbeelding 2 van 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite L305-S5946 RAM Replacement: stap 6, afbeelding 2 van 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite L305-S5946 RAM Replacement: stap 7, afbeelding 2 van 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael Erberich
130 Reputatie
9 handleidingen geschreven
Cal Poly, Team 3-49, Amido Spring 2013 Lid van Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 831
