Inleiding
Use this guide to replace the keyboard in your Toshiba Satellite L305-S5946. Unresponsive or sticky keys are good indicators that the keyboard should be replaced. You must remove the keyboard to access the base housing.
Wat je nodig hebt
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
