Inleiding
If your speakers lose their sound quality or stop working, it is possible to replace them.
In step 6, it is possible to strip the threading on certain screw holes if the screws are not fully removed before the computer cover is removed.
All of the screws in steps 1-2 and 7 can be unscrewed using a #00 Phillips head screwdriver.
Wat je nodig hebt
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Close the laptop and flip it over onto its back.
Remove the eleven 6.6 mm type-00 Phillips head screws along the perimeter and in the center of the laptop, per image 1.
