Inleiding
If your keyboard is damaged or not working properly, it is fairly easy to replace.
Onderdelen
Geen onderdelen nodig.
  1. Close the laptop lid and flip the laptop over.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Push the release button to the right.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
    • Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard.
    • Using your fingers, remove this long piece of plastic gently.
    • Do not apply too much force when removing the cover piece as it can break.
    • Remove the two 4.8 mm type-0 Phillips head screws located underneath the plastic cover piece.
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • DO NOT pull out the keyboard after its out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Conclusie
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 andere personen hebben deze handleiding voltooid.
Juan
109 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-5, Maness Winter 2013 Lid van Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 Leden
5 handleidingen geschreven
Één commentaar
It's not so easy to do step 3.
Texas Chick - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 18
Altijd: 2,763
