Inleiding
If the hinges become loose from wear and tear or break, creating hassle when using the computer, on your Toshiba Satellite L305-S5875, this guide walks you through how to access and tighten, or replace as needed, the hinges on your Toshiba Satellite L305-S5875.
Wat je nodig hebt
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Close your laptop and flip it over.
Remove the 13 screws using a Phillips #00 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
