Ga door naar hoofdinhoud
Toshiba Satellite L305-S5875 CCFL Tube Replacement
Wat je nodig hebt
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 2, afbeelding 2 van 2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 4, afbeelding 3 van 3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 5, afbeelding 3 van 3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 6, afbeelding 1 van 1
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: stap 7, afbeelding 1 van 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: stap 7, afbeelding 2 van 2
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 8, afbeelding 3 van 3
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: stap 9, afbeelding 2 van 2
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler
208 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-1, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 563
