Ga door naar hoofdinhoud
Toshiba Satellite L15W-B1320 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Conclusie
Elizabeth Zapata
190 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,278
