Ga door naar hoofdinhoud
Toshiba Satellite E45t-B4300 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Bottom Case: stap 3, afbeelding 1 van 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 1 van 3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 2 van 3 Toshiba Satellite E45t-B4300 Hard Drive Replacement, Hard Drive: stap 7, afbeelding 3 van 3
    • Use the point end of the spudger to lift the the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Use an opening tool or your fingers to lift the hard drive out of the laptop.
  9. Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite E45t-B4300 Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • Unplug the hard drive from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joshua Swanson
701 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G2, Sullivan Spring 2017 Lid van USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 2,763
