Inleiding
Use this guide to replace a defective fan and heatsink in a Toshiba Satellite E45t-B4300.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
Remove the four 2mm screws with a Phillips #0 screwdriver.
Remove the two 2mm screws with a Phillips #0 screwdriver.
Bijna klaar!
Conclusie
