Ga door naar hoofdinhoud
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
Wat je nodig hebt
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: stap 1, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: stap 1, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 2, afbeelding 2 van 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 3, afbeelding 3 van 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: stap 4, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: stap 4, afbeelding 2 van 2
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: stap 6, afbeelding 2 van 2
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
Conclusie
Eduardo
411 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 442
