Inleiding
While replacing the speakers for the Toshiba Satellite E45t-B4204 you may want to ground yourself before taking things apart to prevent damaging components of the computer. Speakers may need replaced if you are not hearing sound from your computer.
Wat je nodig hebt
Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
