Ga door naar hoofdinhoud
Toshiba Satellite E45t-B4204 Speaker Replacement
Wat je nodig hebt
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: stap 1, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: stap 1, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: stap 4, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: stap 4, afbeelding 3 van 3
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the speakers.
Conclusie
Emily Bateman
97 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G3, Wilson Summer 2019 Lid van IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 571
