Ga door naar hoofdinhoud
Toshiba Satellite E45t-B4204 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: stap 1, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: stap 1, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 2, afbeelding 2 van 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 3, afbeelding 3 van 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: stap 4, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 5, afbeelding 2 van 2
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 6, afbeelding 2 van 2
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 7, afbeelding 2 van 2
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 8, afbeelding 2 van 2
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 9, afbeelding 3 van 3
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 10, afbeelding 2 van 2
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 11, afbeelding 2 van 2
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 12, afbeelding 1 van 2 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 12, afbeelding 2 van 2
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 13, afbeelding 3 van 3
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 14, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 14, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 14, afbeelding 3 van 3
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 15, afbeelding 1 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 15, afbeelding 2 van 3 Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 15, afbeelding 3 van 3
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 16, afbeelding 1 van 1
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: stap 17, afbeelding 1 van 1
    • Remove the keyboard.
Conclusie
Youdong Yan
229 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G3, Wilson Summer 2019 Lid van IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 Leden
6 handleidingen geschreven
Één opmerking
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 541
