Ga door naar hoofdinhoud
Inleiding
The solid state drive, or SSD in short, has the same functionality of the hard drive in storing data, but without a magnet. If the SSD is damaged from long time use or being given the wrong data, then a replacement for the SSD may be necessary.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure the device is off and is not charging by an adapter.
    • Make sure the device is off and is not charging by an adapter.
    • Flip the laptop so that the back panel is visible.
  2. Unscrew twelve 5 mm  screws from the back panel with the Phillips #1 screwdriver. Unscrew twelve 5 mm  screws from the back panel with the Phillips #1 screwdriver.
    • Unscrew twelve 5 mm screws from the back panel with the Phillips #1 screwdriver.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Pry the back panel open with the plastic spudger.
    • Pry the back panel open with the plastic spudger.
    • Pry it gently so that the back panel does not crack.
    • You could also pry the back panel open with your nails.
  5. Remove the single 3 mm black screw using a Phillips #1 screwdriver. Remove the single 3 mm black screw using a Phillips #1 screwdriver.
    • Remove the single 3 mm black screw using a Phillips #1 screwdriver.
  6. Pull the SSD away from the motherboard.
    • Pull the SSD away from the motherboard.
Conclusie
James Nguyen
546 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G4, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G4
3 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 11
Altijd: 70
