Ga door naar hoofdinhoud
Toshiba Satellite E45T-A4300 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: stap 6, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: stap 6, afbeelding 2 van 2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: stap 9, afbeelding 1 van 1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 10, afbeelding 1 van 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 10, afbeelding 2 van 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: stap 11, afbeelding 1 van 1
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 13, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: stap 14, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: stap 14, afbeelding 2 van 2
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 16, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 17, afbeelding 1 van 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 17, afbeelding 2 van 3 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 18, afbeelding 1 van 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Remove the motherboard from the device.
Conclusie
James Nguyen
573 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G4, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 684
