Ga door naar hoofdinhoud
Inleiding
The hard drive is what stores all the memories of the laptop. If the hard drive is damaged, then the laptop won’t ‘remember’ how to be a laptop anymore. A replacement in the hard drive will be needed to bring back the laptop to life.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure the device is off and is not charging by an adapter.
    • Make sure the device is off and is not charging by an adapter.
    • Flip the laptop so that the back panel is visible.
  2. Unscrew twelve 5 mm  screws from the back panel with the Phillips #1 screwdriver. Unscrew twelve 5 mm  screws from the back panel with the Phillips #1 screwdriver.
    • Unscrew twelve 5 mm screws from the back panel with the Phillips #1 screwdriver.
  3. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  4. Pry the back panel open with the plastic spudger.
    • Pry the back panel open with the plastic spudger.
    • Pry it gently so that the back panel does not crack.
    • You could also pry the back panel open with your nails.
  5. Remove the three 7mm black screws using the Phillips #1 screwdriver.
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  6. Remove the hard drive’s connection port with grooved tweezers.
    • Remove the hard drive’s connection port with grooved tweezers.
  7. Pull the hard drive out of the hook and remove it from the device. Pull the hard drive out of the hook and remove it from the device.
    • Pull the hard drive out of the hook and remove it from the device.
Conclusie
James Nguyen
546 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G4, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G4
3 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 19
Altijd: 128
