Wat je nodig hebt
Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
You don't need to remove all the screws - only the two that are directly above the battery compartment. Tried it myself!
Tengo una duda, es unicamente esta bateria la que hay que reemplazar o existe alguna bateria interna que tambien se daba reemplazar?
