Ga door naar hoofdinhoud
Toshiba Satellite E105-S1602 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Conclusie
Ian Washburne
59 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-21, Forte Winter 2013 Lid van Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,554
