Ga door naar hoofdinhoud
Toshiba Satellite E105-S1602 Front Panel Replacement
Wat je nodig hebt
  1. Toshiba Satellite E105-S1602 Front Panel Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 2, afbeelding 2 van 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: stap 3, afbeelding 1 van 3 Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: stap 3, afbeelding 2 van 3 Toshiba Satellite E105-S1602 Front Panel Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 4, afbeelding 2 van 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 5, afbeelding 2 van 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 7, afbeelding 1 van 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 8, afbeelding 2 van 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Front Panel Replacement, Front Panel: stap 9, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement, Front Panel: stap 9, afbeelding 2 van 2
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 10, afbeelding 2 van 2
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 11, afbeelding 2 van 2
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 12, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 12, afbeelding 2 van 2
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 13, afbeelding 3 van 3
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 14, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 14, afbeelding 2 van 2
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 15, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 15, afbeelding 2 van 2
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 16, afbeelding 1 van 2 Toshiba Satellite E105-S1602 Front Panel Replacement: stap 16, afbeelding 2 van 2
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Front Panel Replacement: stap 17, afbeelding 1 van 1
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
Conclusie
Ian Washburne
59 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-21, Forte Winter 2013 Lid van Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 909
