Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide is designed to help you quickly and safely replace the display screen when a problem arises. The display assembly includes the LCD, the front glass, and the display enclosure.
Onderdelen
Geen onderdelen opgegeven.
  1. Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
    • Slide both of the latches to the outside to release the battery.
  2. Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard. Pry the top plastic strip from the top of the keyboard. Peel the strip completely away from the keyboard.
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard. Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it. Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half. Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Locate the four silver screws on the front panel. Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Flip the laptop over and locate all seven screws on the bottom of the laptop. Unscrew all seven Philips#00 7.70mm screws.
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment. Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Rotate the laptop so the back faces you. Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Use the plastic opening tool to pry the top panel up from the base of the computer. Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base. Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Locate the ribbon cable from the motherboard. Using plastic removing tools, pop the ribbon base from the motherboard.
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Locate the two plugs from the motherboard. Using plastic opening tools, remove each plug from the motherboard.
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Locate the ribbon cable partially hidden under the front panel. Using plastic opening tools, pop out the ribbon cable from the motherboard.
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen Using your fingernail, remove each cover in order to expose the screw.
    • Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen
    • Using your fingernail, remove each cover in order to expose the screw.
  19. Remove the four Philips #00 4.85mm screws located at each corner of the screen.
    • Remove the four Philips #00 4.85mm screws located at each corner of the screen.
  20. Insert the plastic opening tool in between the screen and the case to peel the plastic case away from the screen. Lift the plastic case away from the rest of the screen.
    • Insert the plastic opening tool in between the screen and the case to peel the plastic case away from the screen.
    • Lift the plastic case away from the rest of the screen.
  21. Locate and remove the two Philips #00 5.65 mm screws in the bottom right and bottom left corners of the screen. The screw in the bottom left corner is attached to a black and white cord in the back casing. To remove the cord from the motherboard, grip the sides of the cord and pull up from the motherboard.
    • Locate and remove the two Philips #00 5.65 mm screws in the bottom right and bottom left corners of the screen.
    • The screw in the bottom left corner is attached to a black and white cord in the back casing.
    • To remove the cord from the motherboard, grip the sides of the cord and pull up from the motherboard.
  22. Locate and remove the eight Philips #00 5.65 mm screws, four on either side of the screen. Lift the screen away from the rest of the laptop.
    • Locate and remove the eight Philips #00 5.65 mm screws, four on either side of the screen.
    • Lift the screen away from the rest of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ian Washburne
59 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-21, Forte Winter 2013 Lid van Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,448
