Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The battery supplies the device with power without having to keep the device plugged into a charger. If your device will not turn on, try plugging it into the charger. If that doesn't work, use this guide to replace the battery.
  1. Slide both of the latches to the outside to release the battery. Slide both of the latches to the outside to release the battery.
    • Slide both of the latches to the outside to release the battery.
  2. Pull the battery out by lifting the battery cover away from the laptop. Pull the battery out by lifting the battery cover away from the laptop.
    • Pull the battery out by lifting the battery cover away from the laptop.
Conclusie
Andrew Godsil
35 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-21, Forte Winter 2013 Lid van Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 605
