Ga door naar hoofdinhoud
Toshiba Satellite Click 2 Pro Wifi Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 2, afbeelding 3 van 3
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 4, afbeelding 2 van 2
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 5, afbeelding 3 van 3
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 6, afbeelding 2 van 2
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: stap 8, afbeelding 1 van 1
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 9, afbeelding 1 van 1
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: stap 10, afbeelding 1 van 1
    • Remove wifi card.
Conclusie
Paul DeOrsey
893 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-3, Catania Spring 2016 Lid van UMass Dartmouth, Team 4-3, Catania Spring 2016
UMASSD-CATANIA-S16S4G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 420
