Ga door naar hoofdinhoud
Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, Screen: stap 1, afbeelding 1 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, Screen: stap 1, afbeelding 2 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, Screen: stap 1, afbeelding 3 van 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 2, afbeelding 3 van 3
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 3, afbeelding 3 van 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 4, afbeelding 1 van 1
    • Your screen is now completely detached from the internal components.
  5. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the copper shield by removing the four Phillips screws that hold the shield in place.
  6. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 6, afbeelding 1 van 1
    • Unplug the battery from the motherboard by pushing the white clip with a metal spudger. You can attempt to use the plastic spudger first, but it may be more difficult.
  7. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 7, afbeelding 2 van 2
    • Remove 2 6mm Phillips #0 screws holding the battery in place.
  8. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery by lifting on the left side, while holding the ribbon cable above it out of the way.
  9. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, RAM Card: stap 9, afbeelding 1 van 2 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement, RAM Card: stap 9, afbeelding 2 van 2
    • Locate the metal cover that is protecting the RAM. It can easily be found in the corner (placed on top of the mother board).
    • Then remove the two pieces of tape towards the edge of the cover.
  10. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 10, afbeelding 2 van 2
    • Using a plastic opening tool, find your way between the cover and motherboard.
    • Lift the plastic opening tool to unfasten the metal cover.
  11. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic opening tool to slightly lift the RAM card itself.
    • Gently unplug the RAM from its slot.
  12. Toshiba Satellite Click 2 L35W-B3204 RAM Card Replacement: stap 12, afbeelding 1 van 1
    • Congratulations! You have safely removed your RAM Card.
Conclusie
Lexi Lannigan
753 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Lid van UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
6 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,013
