Ga door naar hoofdinhoud
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Wat je nodig hebt
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 5, afbeelding 1 van 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: stap 7, afbeelding 1 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: stap 7, afbeelding 2 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: stap 7, afbeelding 3 van 3
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 8, afbeelding 3 van 3
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 9, afbeelding 2 van 2
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 10, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 11, afbeelding 1 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 11, afbeelding 2 van 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: stap 11, afbeelding 3 van 3
    • Open the laptop and remove the display assembly from the keyboard assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Hook
439 Reputatie
4 handleidingen geschreven
IUPUI, Team S1-G6, Hovde Fall 2019 Lid van IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 281
