Ga door naar hoofdinhoud
Toshiba Satellite CL15t-B1204X Power Connector Replacement
Wat je nodig hebt
  1. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 3, afbeelding 1 van 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 4, afbeelding 1 van 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 5, afbeelding 1 van 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 6, afbeelding 1 van 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: stap 7, afbeelding 1 van 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: stap 7, afbeelding 2 van 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: stap 7, afbeelding 3 van 3
    • Disconnect the charging connector from the motherboard using the blue iFixIt opening tool by sliding it away from the connector.
  8. Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: stap 8, afbeelding 3 van 3
    • Pry the power connector upwards from the side of the laptop using the opening tool, then remove the part from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Hook
439 Reputatie
4 handleidingen geschreven
IUPUI, Team S1-G6, Hovde Fall 2019 Lid van IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 276
