Ga door naar hoofdinhoud
Toshiba Satellite CL15t-B1204X Speaker Replacement
Wat je nodig hebt
  1. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 3, afbeelding 1 van 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 5, afbeelding 1 van 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 6, afbeelding 1 van 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: stap 7, afbeelding 1 van 2 Toshiba Satellite CL15t-B1204X  Speaker Replacement, Speaker: stap 7, afbeelding 2 van 2
    • Carefully unplug the speaker's cord from the I/O board.
  8. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the two 3mm screws with the PH1 screw head on each speaker found on the corner's away from the hinges.
  9. Toshiba Satellite CL15t-B1204X  Speaker Replacement: stap 9, afbeelding 1 van 1
    • Remove the speakers.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 188
