Ga door naar hoofdinhoud
Toshiba Satellite C875-S7304 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to display the keyboard.
  7. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Using the iFixit opening tool, carefully remove the black plastic bar below the keyboard.
  8. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Pry the keyboard up and apart from the device.
    • Disconnect the ribbon cable under the keyboard.
  9. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove all eight of the screws under the keyboard.
  10. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Close the device and carefully flip it back over.
  11. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 11, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 11, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel and remove panel.
    • Slide the hard drive laterally first and then lift the hard drive up using the clear tab.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  12. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Use a Phillips #1 to remove all 15 of the screws holding the bottom panel intact.
  13. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Grab the optical drive on either side.
    • Pull the drive out of the device laterally.
  14. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 14, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 14, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Gently pry open the entire bottom panel, pulling upward to remove the panel from the device.
  15. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 15, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 15, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Remove all wiring from the motherboard and pry it from the device slowly making sure that no ribbons or wires are connected.
  16. Toshiba Satellite C875-S7304 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Gently remove the motherboard from inside the device. You are now ready to replace the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emma King
334 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 1,665
