Ga door naar hoofdinhoud
Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite C875-S7304 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C875-S7304 Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: stap 4, afbeelding 1 van 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery out carefully using two hands.
Conclusie
Emma King
334 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 643
