Inleiding
This guide will show you how to remove your laptops hard drive. This process requires a small Phillips Head screwdriver and your hands. There will be several small screws removed, so be sure you have a place to store them as you work to keep from losing any.
Wat je nodig hebt
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
4 andere personen hebben deze handleiding voltooid.
