Ga door naar hoofdinhoud
Toshiba Satellite C855D-S5303 Disc Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: stap 1, afbeelding 1 van 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: stap 1, afbeelding 2 van 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: stap 1, afbeelding 3 van 3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: stap 2, afbeelding 1 van 1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: stap 3, afbeelding 2 van 2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Courtney Burns
836 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 359
