Ga door naar hoofdinhoud
Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C855D-S5303 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: stap 3, afbeelding 1 van 1
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite C855D-S5303 Battery Replacement: stap 4, afbeelding 2 van 2
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: stap 5, afbeelding 1 van 1
    • The battery can now be pulled out entirely. You are ready to replace it.
Conclusie
Courtney Burns
836 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Leden
10 handleidingen geschreven
Één opmerking
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 999
