Inleiding
Motherboards can get damaged or worn out for a variety of reasons, including physical damage, exposure to water, age, or even bad quality. This guide will show, step by step, how to remove the motherboard from a Toshiba Satellite C855D-S5109 laptop in order to replace it.
Motherboard failure will almost always result in a catastrophic failure of the laptop, so if your laptop completely refuses to turn on and you’ve already checked the battery, replacing the motherboard may restore functionality to your machine.
Wat je nodig hebt
Using a Jimmy, slowly lift the keyboard up and away from the palm-rest. Slowly work around the edges, pushing the clips back, prying the keyboard up with minimal force.
In the area under the keyboard, disconnect the first cable that is located inside of the square near the front right of the laptop.
Disconnect the next two cables that are located inside of the square located at the back right of the laptop.
Één andere persoon heeft deze handleiding voltooid.
