Inleiding
This is a basic guide on how to remove and replace a cooling fan in a Toshiba Satellite C855D-S5109. The cooling fan is responsible for keeping the motherboard and CPU cool during operation. Cooling fans can either become excessively dirty with dust buildup, which will cause noisy or inefficient operation, or can cease function completely, which can cause slower performance or for your device to overheat. This guide will show you how to access the Toshiba Satellite C855D-S5109’s fan for replacement or cleaning.
Wat je nodig hebt
Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
Remove the L-Shaped panel.
Remove the twelve 6 mm screws from the back of the laptop with a Phillips #00 screwdriver.
