Inleiding
The hard disk drive is an essential component to a laptop. This guide will show you how to safely remove and replace your hard disk drive when your device needs a new one.
Wat je nodig hebt
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
Bijna klaar!
Conclusie
