Inleiding
You might need to replace your CMOS (Complementary Metal Oxide Semiconductor) battery if your Toshiba laptop is losing its time and date settings or if you are receiving a CMOS error message. You will also need to remove your CMOS before replacing other elements, such as the motherboard.
Wat je nodig hebt
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Remove the 7mm screw from the back panel using the Phillips head screwdriver.
