Inleiding
Please remember to disconnect and remove all power sources before beginning disassembly, including AC power cord and battery.
Wat je nodig hebt
To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
Using two fingers, push down on the aluminum rods on the sides of the RAM module
Één andere persoon heeft deze handleiding voltooid.
