Ga door naar hoofdinhoud
Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 3, afbeelding 3 van 3
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement, Back Access Panel: stap 4, afbeelding 1 van 3 Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement, Back Access Panel: stap 4, afbeelding 2 van 3 Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement, Back Access Panel: stap 4, afbeelding 3 van 3
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
  5. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement, Optical Disk Drive: stap 5, afbeelding 1 van 1
    • Remove the 3mm screw located under the back access panel nearest the optical drive with a P1 driver.
  6. Toshiba Satellite C75D-A7370 Optical Disk Drive Replacement: stap 6, afbeelding 1 van 1
    • Gently grab and pull the optical drive out of the laptop from the outside.
Conclusie
Chris Purdie
428 Reputatie
4 handleidingen geschreven
USF Tampa, Team 16-1, Blackwell Spring 2017 Lid van USF Tampa, Team 16-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 336
