Ga door naar hoofdinhoud
Toshiba Satellite C675-S7106 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite C675-S7106 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 RAM Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C675-S7106 RAM Replacement: stap 2, afbeelding 2 van 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 RAM Replacement, RAM: stap 3, afbeelding 1 van 2 Toshiba Satellite C675-S7106 RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0 head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 RAM Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite C675-S7106 RAM Replacement: stap 4, afbeelding 2 van 2
    • Unclip and move the two metal clips on either side of one or either RAM stick.
    • Pull the stick outwards as you lift it upwards.
    • When reinstalling, ensure that the contacts are completely covered and connected.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua Steakelum
451 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 242
